Каква е разликата двигателите на Yamaha YZ 450 F и Yamaha WR 450 F? Много ми е интерестно да зная защото би трябвало да има доста разлика. Все пак едното е чист крос другото е ендуро . Ако може дайте ти ми пълна информация. Интересувам се особено много...
Двигателите на Yamaha YZ 450 F и Yamaha WR 450 F?
Ето спесификациите на двата мотоциклета. На практика в двигателите няма разлика, но скоростите им са различни и в констукциите има леки промени.
General information
Model: Yamaha WR 450 F
Year: 2005
Category: Enduro / offroad
Rating: 69.6 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 449.00 ccm (27.40 cubic inches)
Engine type: Single cylinder
Stroke: 4
Compression: 12.5:1
Bore x stroke: 95.0 x 63.4 mm (3.7 x 2.5 inches)
Fuel system: Carburettor
Valves per cylinder: 5
Fuel control: DOHC
Cooling system: Liquid
Gearbox: 5-speed
Transmission type
final drive: Chain
Physical measures
Seat height: 996 mm (39.2 inches) If adjustable, lowest setting.
Wheelbase: 1,483 mm (58.4 inches)
Overall length: 2,169 mm (85.4 inches)
Overall width: 826 mm (32.5 inches)
Overall height: 1,300 mm (51.2 inches)
Ground clearance: 371 mm (14.6 inches)
Chassis and dimensions
Front suspension: 46mm Kayaba inverted telescopic fork w/adjustable compression and rebound damping
Front suspension travel: 300 mm (11.8 inches)
Rear suspension: Kayaba single shock w/adjustable preload, compression and rebound damping and separate hi/lo-speed compression adjuster
Rear suspension travel: 318 mm (12.5 inches)
Front tyre dimensions: 80/100-21
Rear tyre dimensions: 110/100-18
Front brakes: Single disc
Front brakes diameter: 250 mm (9.8 inches)
Rear brakes: Single disc
Rear brakes diameter: 245 mm (9.6 inches)
Other specifications
Fuel capacity: 9.84 litres (2.60 gallons)
Color options: Team Yamaha Blue/White
General information
Model: Yamaha YZ 450 F
Year: 2005
Category: Cross / motocross
Rating: 78.4 out of 100. Show full rating and compare with other bikes
Stroke: 4
Compression: 12.5:1
Valves per cylinder: 1
Fuel control: SOHC
Gearbox: 5-speed
Transmission type
final drive: Chain
Physical measures
Wheelbase: 59 mm (2.3 inches)
Overall length: 2,172 mm (85.5 inches)
Overall width: 828 mm (32.6 inches)
Overall height: 996 mm (39.2 inches)
Rake (fork angle): 27.2°
Front suspension: 48mm Kayaba inverted telescopic fork w/adjustable compression and rebound damping
Front tyre dimensions: 80/80-21
Rear tyre dimensions: 110/90-19
Fuel capacity: 6.81 litres (1.80 gallons)
Color options: Team Yamaha Blue/WhiteЕндурото и сексът не са шега работа !
Животът се измерва с броят на издишванията !
http://sixdayscrazyjob.com
http://crazy-job.com
1. Има разлика в градусите на предният разпределителен вал.
2. 1-ва скорост на yz-та е близка на 2-ра на wr-a.
3. yz-a е с по лек магнет и няма генератор за фар и стартер естествено.
4. yz-a е с отворен ауспух и филтърна кутия, поради което и карбуратора е с различни настройки.
Незнам да има лесен и елегантен начин
Най доброто което съм срещал е:
http://www.elineaccessories.com/lightingcoils.html
петре няма смисъл да взимаш YZ и да му слагаш фар по добре направо взимай WR
YZ та се кара много по трудно на ендуро повярвай ми
1 ва та на YZ е толкова дълга че качването по технични и трудни пътеки с кросовия модел е трудно, и накрая ще му изпържиш съединителя някъде освен това WR а си има и стартер което е мнооого голям плюс по чукарите има си и фар и всичко останало
един приятел австриец преди все си взимаше YZ-F -и щтото кара мотокрос а и ендуро но от няколко години мина на WR и ми каза че повече кросов мотор няма да си вземе
според него късата първа и фара са много голям плюс
освен това според него WR -е с много по добро окачване
а трябва да знаеш че човека знае какво говори
даже и с WR-а участва на мотокросове и то много успешно а е на 40-41г последното състезание в хърватска завършил директно след нашия Куманов а Куманов го знаеш кой е и къде участва
те в България на старо ги няма а на запад тези на старо струват колкото тия дето в Пловдив ги продават чисто нови
па и от по старите модели и на запад ги няма много много а и не са за взимане от първите модели щото имат много конструктивни недоизпипани неща които при по новите са подобрени
все пак тези мотори от 2001г първо ямаха ги пусна другите фирми едва от миналата година предлагат 250 4т има още много неща които ще търпят развитие
http://www.offroad-bulgaria.com/view...978&highlight=
Първоначално публикуван от tatkobarbahttp://bikeandsleds.com/Bulgaria.htm
Като гледам има данни за доставчика ...
А чували ли сте за Еди от Хотел-Ресторант Еди в Симеоново (или нещо такова)... занимавал се с внос на нови мотори по поръчка и ги внасял сравнително тънко ...Път без препятствия обикновено не води до никъде.
